1972 F350 crewcab 4x4
zakt
Post by zakt »
Well have another 2wd project... :roll:
1995 rear F350 seats installed:
1967 steel grill (hate the plastic inserts on the 72):
1999 suburban front captain seats (power 6 way driver side), in the works (passenger side below):
1995 F350 460 EFI (7.5) motor, complete harnesses:
1972 Ford F350 crewcab
BiggDogg
Re: 1972 F350 crewcab 4x2
Post by BiggDogg »
Looking good :thup: that rear seat looks right at home :D
1970 F250 Camper Special
dablack00
Post by dablack00 »
Looks really good. What trans are you planning on running. If you want to run a C6 or manual, I hope that computer is from a manual trans truck. If it is from a truck with an auto trans, then you will have to run an E4OD. The computer will expect a trans signal in order to run right. Of course if the 460 and computer are from a manual trans truck it won't care what transmission is there.
Cool project. Are you planning on hopping up the 460? Just remember you have a speed density computer there and it has trouble with some performance parts.
Austin
fomocoguy
Post by fomocoguy »
Neat! I'd like to see where this is going. In some far off pipe dream I have I think it would be cool to find a newer fi 460 and trans to install in my crew. For now I'm just looking for a deal on a holley projection unit to install on my 360. :thup:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
zakt
Post by zakt »
Runnin the C6 with the gear vendors under/over aux trans. I will be converting the 460 to sequential Mass-Air http://www.mass-air.com/Products.htm so should be good on the trans. (comes with a new computer)
Todd
zakt
Post by zakt »
Finally got the 72 in the garage to start messing with... working on getting the D70 out and putting the ford 10.25 in. Cutting perches off the D70 to weld on the ford 10.25. Will have detroit truetrac,4:56 gears, TSM disk brake conversion and long pinion with new 1410 yolk.
zakt
Post by zakt »
looking at a parts truck today to see if its worthy to be cut up for crewcab patch pieces :pop:
rjewkes
Post by rjewkes »
Looks like it, plus it comes with custom steering wheel and wheels. you can even keep extra parts or sell em to raise fu nds even good deal :thup:
zakt
Post by zakt »
I mainly want the bed as mine has a wavey floor and the bed sides seem to be tweeked (gap one side not other and tailgate issue closing) then I have holes in my front doors someone hacked for speakers.. I think there were stock but they enlarged them ... I also have rusted up cab corners so this might have good ones also... So seems to be a perfect match to my needs. Will post things for sale for sure looks like a set of western junior mirrors also.
Todd
zakt
Post by zakt »
Well the truck above didnt work out... was in an accident none of the front lines up, inner fenders rusted out, look like core support needed some help also... getting pictures of this and might go pick it up this weekend :drive:
BiggDogg
Post by BiggDogg »
Wow... Trim :drool: Good luck trying to pick parts and not end up with another project :P
zakt
Post by zakt »
The front bed inner brackets are bent so will have to replace those other than that doesnt look to bad
zakt
Post by zakt »
Got the 69 F250 home 3hrs each way (6hrs) so not all that bad... towbar worked great.
zakt
Re: 1972 F350 crewcab 4x4
Post by zakt »
The front crossmember had a dent in the back so got that fixed and temp installed but doesnt line up so will take the truck to the frame shop and have them fix it so it fits right in.
Now got all the crossmembers off and brackets...just the front of the 4x4 frame left to cut off the engine crossmember... still debating though if I should use the 4x4 one or keep the 2wd one on....
