spool vs mini spool
- 68swb
spool vs mini spool
i am sure that this has been talked about several times, but what is the difference between the two? is the mini spools purpose to lock the axles together all the time and a spool more less like limited slip.... is this right, did i answer my own question????? thanks guys....
"I got this"
68 swb 429ci 3spd
69 lwb f250 360 4spd
75 VW superbeetle
79 F250 4X4 supercab 400 4spd
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
- FORD428CJ
Re: spool vs mini spool
A spool is a spool. They both lock up the rear. The mini spool is smaller and fit OEM Open type (non limited-slip) differentials. Hope this helps!?
Spool
http://www.jegs.com/i/Strange+Engineeri ... 5/10002/-1
Mini Spool
http://www.jegs.com/i/Auburn+Gear/109/544809/10002/-1
Spool
Mini Spool
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
- FORD428CJ
I should + that the Spool takes the place of the Original Differential Case.
http://store.summitracing.com/egnsearch ... toview=sku
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- 68swb
so either way it is put, they are mainly for racing or off road use, being that they lock the axles together.... and on turns there will be wheel hop or chirp?
"I got this"
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
- FORD428CJ
YES. That is true. Look into the Lockers, True Track or the limited Slips. I'm not one for welding gears, because I don't like to be stranded out in the middle of no mans land! The choice is yours and good luck to ya!!!!68swb wrote:so either way it is put, they are mainly for racing or off road use, being that they lock the axles together.... and on turns there will be wheel hop or chirp?
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
- 68swb
i dont want to weld my rearend up, i was just using it as a comparision for me to get a full understanding about the differnece, thanks guys for the info. i am going to look for a cheep limited slip carrier or something like it, if not i will just keep what i have, i dont plan on doing anything carzy with it. at the moment.
"I got this"
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
- averagef250
I've seen several brand new powrlok carriers improperly machined with far too much runout in a recent years. Welding the spiders to the carrier does not weaken anything when done correctly. It's definitely irreversible once you do it, but for most common axles a complete replacement open carrier is not an expensive thing if you ever wanted to go back. Welding the spiders together is essentially a home made mini-spool. You're forcing the crosspin(s) to take the entire brunt of turning the axleshafts. Makes your diffy only as strong as the crosspin.
