Wanting to do a swap.
papabug71
Post by papabug71 »
Here is what im thinking..... My in-laws have a 72' F-350 & its built like a brick....you know... Anyways its a 2wd 390 truck with a NP435, PS,PB, & the biggest radiator I have ever seen in one of these trucks. If I can get them to part with it, I would give my left one to swap everything mentioned into my truck. Always wanted a 390 4 speed combo. Everything, & I mean everything should swap shouldnt it?
I can handle the power steering, but.....
Can I use the short drive shaft from the 1 ton on my 1/2 ton? (its a SWB truck & mine is a long bed) EDIT: I just remembered. Nevermind.
Can I use the power brakes since its power drums & not disc? Or will the valve be different because it has 1 ton brakes?? I would imagine some new brake lines will be in order as well.
This truck is absolutely built to the hilt. The front drums on this thing are massive, not to mention the DANA 70 rear end with 3:73'ish gears. The motor is good, its been sitting for a couple of years now, but I have drove it numerous times in the past. It drives like a freekin caddy with the PS & PB. Plus its been on propane since it was new so the motor should be nice & clean. Too bad the cab is absolutely GONE on it, or it would be a prime canidate for a resto.
What do you guys think?? :help:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
stangconv
Re: Wanting to do a swap.
Post by stangconv »
I would be tempted to just swap your body onto the other frame...
to get power brakes the booster will swap over and you will reuse your master cylinder.
papabug71
Post by papabug71 »
stangconv, dont think I havent thought about it! I do have a parts truck, but the cab on it isint any better. It would be a hoss of a truck if someone could bring it out of "farm truck" status.
The hard part is talking my in-laws into letting it go. They bought it brand spankin' new in Dallas Tx. & drove it up here to the ranch. Its been here its entire life....
I'll try to get it from them & go from there. Thanks guys!! :fr:
Matt
Mine since 5/7/'94
RedneckTexan
Post by RedneckTexan »
I'm with stangconv, just swap a new cab on the frame and drive it like that! :D F-350's are awesome trucks! :D
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
papabug71
Post by papabug71 »
What I wouldnt give......
Matt
Mine since 5/7/'94
sideoilerfe
Post by sideoilerfe »
If the drive train is good, then I'd definitely find another body. It would be a sin to part out a truck like that.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
papabug71
Post by papabug71 »
We will have to see. Right now im too broke to do anything, so everything is on hold. Work has really slowed down! :pout:
Matt
Mine since 5/7/'94
willowbilly3
Post by willowbilly3 »
A dually?
I vote leave it on the farm unless you are certain you can do it justice. Find a good cab first.
