FMX filler tube leak help
69rangerman
Post by 69rangerman »
I finally found out that my tranny was leaking from the filler tube where it goes into the case. I did purchase a new O-ring (2 in fact), and it slowed it down a little but I think the filler tube is just a bit to tweaked, dented, and out of round to get a good seal.
Does anyone have any ideas about other / additional ways to improve the seal in this area?
Would C4 or 6 tube work?
Thanks for any reply.
Tom/FL.
:fr:
"O say, does that star spangled banner yet wave? Oer the land of the free and the home of the brave?" It does at my house! God bless America!
FordTruck
Re: FMX filler tube leak help
Post by FordTruck »
I got the filler tube off of the old FMX that I had in my 70 if your interested.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
it could be the size of the oring you are using. there are several types and sizes of those. the one you have may not be think enough. it may be the correct size around. but it may not be think enough the other way. if you know what i mean.
ares360
Post by ares360 »
are these trannys any good?
Kane
FordTruck
Post by FordTruck »
ares360 wrote:are these trannys any good?
I've herd mix things about them. I have the one out of my 70 it was rebuilt but it started slipping really bad so I switched out for a C6. I probably could have chanded the filter and fluid and maby adjusted the bands but too much work for me so I took the easy route :lol:
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
ares360
Post by ares360 »
ok, cause I might have picked up a 400 ci small block with an fmx. I guess I will just have to see what happens.
sorry for stealing the tread 69rangerman
Kane
c6 is better than a fmx
FordTruck
Post by FordTruck »
fordman wrote:c6 is better than a fmx
Agreed, isn't an FMX just a built C4?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
F-100Ranger
Post by F-100Ranger »
I see the comments about the C-6 being better than the FMX all the time.
To quote Stuart Anderson from the Ford Transmission Forum at www.network54.com
"The C6 will use lots more horses than the FMX. If the FMX is done properly it will stand up to what the C6 has to offer."
There's something like a 14 hp loss for the FMX vs. 45 hp for the C-6.
67 Austin Healey 3000- resto - subframe rebuilt so far
68 F-100 LB w FE410-in progress frame-off resto
02 Sebring Convertible- for top-down relaxation
69rangerman
I've done alot of reading on the FMX vs. others, including the Stuart Anderson website. I try to keep this one going because it's original to the truck along with all the other major bits. I wish I could afford to have it rebuilt, and that there were more repair parts for it.
My opinion is that any tranny that was originally spec'd behind everything from a 302 to a big block in some wopper 70's lead sleds is probably a very durable tranny, and able to take some pretty good torque.
I also like that it is fully manual and gears may be selected and kept as long as required.
Anyhow...my latest attempt at the fix is to use a few different types of o-rings from True Value, and lock them in place (they keep slipping up the tube) with a small metal hose clamp above them.
I let it run for a while and will know in a few days if this helped.
Thanks for the replies.
:fr:
