Does not having a kickdown really kill a tranny??
FordTruck
Post by FordTruck »
My brother told me that not having a kickdown on my C6 will kill the tranny really quick. Is that true becuase I don't have a kickdown on my C6?? And its gonna be my daily driver and if it'll kill i'll put it toward the top of my list to get one.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
BobbyFord
Re: Does not having a kickdown really kill a tranny??
Post by BobbyFord »
It will not affect the trans at all.
FordTruck
Post by FordTruck »
BobbyFord wrote:It will not affect the trans at all.
Sweet thanks!!
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
My427stang
Post by My427stang »
Not a a C-6 or C-4, but if you were running an AOD it would. The TV cable / kickdown also adjusts pressure for throttle movement
willowbilly3
Post by willowbilly3 »
My427stang wrote:Not a a C-6 or C-4, but if you were running an AOD it would. The TV cable / kickdown also adjusts pressure for throttle movement
That's what I was thinking too, many people mistake the tv cable for a kickdown.
My ex had a bronco with a 300 C6 when I met her and it had no kickdown. The body rusted off it at 200,000 but the tranny still worked fine. It did get into top gear very quickly though and if you needed second gear you had to shift it down manually.
FordTruck
Post by FordTruck »
Ok well i guess i don't need to get a kickdown for awhile. Someday i'll one but i've got bigger fish to fry right now :lol: Will it make it harder to find a kickdown since my tranny's out of an 80's F150 Or can i just use one off any auto ford truck??
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
i think it works lik ethis . but i cant confirm it. if you have a big lock you need a rod from a big block. if you have a small block you need one from a small block.
