C6 Trans won't shift out of park
fordtruckparts
Post by fordtruckparts »
HELP!!
I just got my C6 rebuilt, and I installed it in the truck, and when I put it into reverse, it just sits there like it is still in park. Same with the forward gears. I have hooked the vacuum line into the trans, hooked up the shift linkage correctly, and filled it with Tranny fluid. Vacuum pressure is 18 inches. I did not rebuild the trans myself, it was done by a professional shop (Mr. Transmission). I would assume that it has been done correctly, but of course, I cannot comment on it for sure.
What do you guys think is the problem here? Where should I look first? :?
1948 Dodge 2.5 Ton, 1959 International Harvester BC-180, 1959 Willys Pickup, 1965 Impala HT, 1965 Galaxie Convertible, 1967 Mercury M-100, 1969 F-250, 1971 F-250, 1976 F250, 1978 F-350, 1979 F-250, 1980 Dodge D-300, 1984 F-250, 1986 F-150, 1987 Chevy Monte Carlo, 1988 F-150, 1988 Mustang, 1990 F-150, 1994 Camaro Z28 LT1
saidyene
Re: C6 Trans won't shift out of park
Post by saidyene »
I would look over everything I had done first then call up the shop that rebuilt it. Being that they were just in the trans they may have an idea what the problem is.
make sure the trans is warm when you check if the fluid is full. then call the mr transmission place.
AlleyCat
Post by AlleyCat »
How much fluid did you put in? A C6 with the converter empty holds about 12 quarts of fluid.
Clay
michael69
Post by michael69 »
Did you get the torque converter seated all the way and flex plate tightened to converter? :?
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
fordtruckparts
I did get the converter seated correctly and the flex plate tightened up. I have about 9 quarts of fluid in it. I also re-checked my hookups and everything is correct. I'm gonna warm it up today and see what the level reads when its warm. I am also going to pull the tranny cooler line off to see if there is any oil coming out. I'll keep everyone posted!
BobbyFord
Post by BobbyFord »
fordtruckparts wrote:I did get the converter seated correctly and the flex plate tightened up. I have about 9 quarts of fluid in it. I also re-checked my hookups and everything is correct. I'm gonna warm it up today and see what the level reads when its warm. I am also going to pull the tranny cooler line off to see if there is any oil coming out. I'll keep everyone posted!
3 quarts low is why it ain't moving...
fordtruckparts
Got it working, topped the fluid up to 12 quarts!! I'll never trust my colourblind dad to tell me what the dipstick says again, haha!! :fr:
