Anyone own any Central Pneumatic tools?
JWW
Post by JWW »
I'm thinking of buying this flange tool from Harbor Freight.
Anyone have any luck with any tools from Central Pneumatic?
Anyone have any suggestions of another type of flange tool they have had luck with?
Thanks
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
71PA_Highboy
Re: Anyone own any Central Pneumatic tools?
Post by 71PA_Highboy »
I have one of those... works just fine for what it is. The tool is extremely simple, so very little can go wrong.
I bought mine in '99, last used it in mar '08. Just waiting for the next project...
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
JWW
Post by JWW »
Thanks Eric. I'm going to go ahead and get one.
JWW
2004 F150 Crew Cab
marxtoys
Post by marxtoys »
I bought one of their rivet guns.
Dave bought one from MATCO.
His is red, mine is blue..... otherwise identical right down to the staples in the little bag of extra pieces.
The nibbler seems to be holding up ok.
"Knowledge is Good." Emil Faber
flatblack
Post by flatblack »
whats that funky tool used for? :hmm:
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
marxtoys
Post by marxtoys »
funky? nay, my good man...... this is one of the true wonders of modern technology.
Squeeze the handle - the tool goes 'kerchunk'. If you are holding the wrong end, you get the blood blister from hell. If you have a piece of sheet metal in that bottom slot, it makes a step, so a patch will fit flush...... In the top slot, it punches a nice neat hole to plug weld.
:thup:
thebannister8
Post by thebannister8 »
i'm a handyman by trade and kill tools now and then....i gave hf&t a try...i own many central pneumatic tools and have found little difference, with a rare expection, from the big buck tools......all my air tools are central pneumatic and all work great...i also have 2 of their compressors and have used them to no end... :thup:
JWW
Post by JWW »
thebannister8 wrote:i'm a handyman by trade and kill tools now and then....i gave hf&t a try...i own many central pneumatic tools and have found little difference, with a rare expection, from the big buck tools......all my air tools are central pneumatic and all work great...i also have 2 of their compressors and have used them to no end... :thup:
Thanks, I'm thinking about getting an air nibbler that they have.
JWW
2004 F150 Crew Cab
The Good Humor Man
Post by The Good Humor Man »
Got one of those bad boys, and it works great.
http://WWW.GoodHumorTrucks.Com
killakobra
Post by killakobra »
JWW wrote:I'm thinking of buying this flange tool from Harbor Freight.
Thanks
i bought one of these about 2 months ago and it works great.
1967 f100 stepside 300ci I6
1972 longbed trailer
drytoast
Post by drytoast »
I use to work for Ingersall Rand where they make air tools and they say the biggest problem people have when the air tools fails, is because they forget to oil them, otherwise they last forever.
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
JWW
Post by JWW »
drytoast wrote:I use to work for Ingersall Rand where they make air tools and they say the biggest problem people have when the air tools fails, is because they forget to oil them, otherwise they last forever.
I agree. I have always heard that WD-40 is a no no when it comes to lubricating air tools.
JWW
2004 F150 Crew Cab
Merlin68F100
Post by Merlin68F100 »
Just get in the habit of dropping a few drops of oil in the chute every day before you use them and the "lesser" tools will last a good while. Also bleed the water out of your compressor everyday. Water inside a non-lubricated air tool will make even the high end tools go nasty on you. :2cents:
"A point in every direction is the same as no point at all."
The Pointless Man
