72 body swap
Re: 72 body swap
boring a block can cost about as much as getting another block.
caraber
Re: 72 body swap
Post by caraber »
well i talked to a friend today and he has a set of honing stones that he thinks might do the trick so im going to go that route and hope for the best :pray:
Chris
Re: 72 body swap
if it will work give it a try.
lee_ford
Re: 72 body swap
Post by lee_ford »
If the rust is not too deep, then a hone will work. Just be sure and check the top 1/4 to 1/2 inch cylinder wall to be sure there is not a bad ridge from ring wear. If there is just use a ridge reamer on the block first to get the cylinder sides level.
My 1969 F100 Gallery
[Please note: A lot of what I write may be common knowledge to some of us. But for a new comer and even us at one time, somebody had to inform us that FIRST time.]
caraber
Re: 72 body swap
Post by caraber »
well i got the 72 down here today it is just as i remembered it virtually rust free :woohoo: so that is the upside of my day. spent the rest of my day trying to get the rust off of the cylinder walls. slow work but it seems to be working. will post pictures of the 72 when i can find my camera again :hmm:
Chris
caraber
Re: 72 body swap
Post by caraber »
well i figure i might want to post some pictures of the heads i have before and after. just realize that the before and after pics of different heads but the amount of the rust was the same
Chris
caraber
Re: 72 body swap
Post by caraber »
and here is the 72 f100 body that is going on the frame
Chris
caraber
Re: 72 body swap
Post by caraber »
well the 360 is shot :cry: so i picked up a 351 for $20 :D and was wondering what it will take to put on the 78 frame, am i going to need new mounts or not. will the transmission work or will i need to replace that one as well? :?
Chris
rjewkes
Re: 72 body swap
Post by rjewkes »
depends on what is or was in the 78. If it was a small block 302-351 it should slide right in. if it was a big block you'll need to swap out the mounts on the frame to small block.
Man i need to find a deal like that on a 351W.
caraber
Re: 72 body swap
Post by caraber »
it had a 360 in it and i take all of my scrap parts to the guy that sold me the running 351 that i helped pull from a 79 f100
Chris
