replace the tss
replace the steering wheel
radius arm bushing
replace bench seat
ordered door panels and arm rest
got newer tires and a aluminum rims
ordered center caps
cut off stock exhaust from glass packs and installed dumps
installed a huge air filter
rewired the brakes and lights to work properly
installed a hood seal
installed newer door seals
installed carpet, door trim
removed bwest coast mirrors and installed sport style mirrors.
this is all about a week and half of work and i have only cracked the surface. will post pics of the befores and afters this week sometime. the 67 has taken a turn to be sacrificed for the 71. it will be giving the bed, hood, fenders, wiring harness (for the f-600 gauge with tache and vacumn) and what ever else i feel i can use to rebuild the 71 with. i also have a set of bucket brackets and a pair of 77 cougar bucket that match up perfectly to put in at a later time as well. also, thanks to a member here, i have a b&m ratchet shifter to be installed. i have collected parts for about 4 years now to make the truck that i want and have now started the process. wish me luck.
hotrod.
