Question about rust encapsulating paint
69rangerf100
Post by 69rangerf100 »
with rust encapsulating paint for the best results what should be done to the frame. i have started sanding down all the years of dirt and crap that is stuck to the frame or just paint over the rust and other krud on the frame
David
HOWDY69
Re: Question about rust encapsulating paint
Post by HOWDY69 »
Remove anything that is loose and follow the manufacture's recommendations for preparation. The attached thread has some good information.
http://www.fordification.com/forum/view ... &sk=t&sd=a
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
I've said it before and I'll say it again....products like POR-15 and Rust Encapsulator cannot protect metal that it's not touching. If you use that stuff over primer, paint, undercoat, etc., it's not protecting the metal at all....and what if that primer/paint/etc. let's go? Then so does the POR-15. If you want it to protect like it's intended, then you need to get all dirt, grease, scaly rust, etc. off first. Surface rust is OK, and in fact that stuff usually adheres better WITH some surface rust.
Prep is the key....if you take the time to follow the manufacturer's instructions to the letter and do it right, you'll probably never have to worry about it again. Take some shortcuts though, and you'll be sorry, 'cause that stuff will peel off like sunburned skin.
69rangerf100
thanks for the advice Keith i was just wondering b/c i was going to sand the frame down anyways
David
papabug71
Post by papabug71 »
I like to use the POR-15 "marine clean" after I have everything scraped & sanded down. Its good stuff & it gets all the fine particles off of the surface. IF you do go with POR-15, be sure to follow the instructions to the T. Its really good stuff & I have had great success with it in the past.
For the record, I have never tried the rust encapsulator stuff from Eastwoods, but im willing to bet its just like POR-15.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
OldRedFord
Post by OldRedFord »
I have had good luck with POR-15.
Also, just because you think something will not get sunlight, top coat the POR-15 anyway like it says.
I did not top coat the rear end on my truck and thought I would have fixed the rust holes in the bed by now. But the sun getting through the holes has messed up the POR-15.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
