I'm lost--need directions
Swellmel
Post by Swellmel »
Got a 68 F100SB(6 cyl/3sp man)--Everything I need for the SB is in a 69 F100LB(390/c6) cab and forward. Do I switchout cabs(if 69 is good enough shape)? Numbers would work for everything except for the difference in SB and LB?
Swellmel
Re: I'm lost--need directions
Post by Swellmel »
Got the 68 home today. Decided to put my extra 302 in it. Any suggestions on how hard I should I build the eng(cam, intake carb, head work).
your questions need more info to give an opinion really. such as how badly is each cab rusted? and as for how to build the engine what are you going to use the truck for?
Swellmel
Post by Swellmel »
Wow, forgot I had this going. Update:
I bought a cab from junkyard and it and everything else off the original except the bed has had a thorough going over and primed and ready for paint.
Bought a 78(351M) and got the front suspension, PS, brakes, and those pesky engine perches.
The brake booster was bad.
Got a steering column for an automatic transmission.
What's my best bet(year) for a booster and pedal assembly?
brake boosters will bolt right up from 68-77.
Swellmel
Post by Swellmel »
fordman wrote:brake boosters will bolt right up from 68-77.
How about a brake pedal assembly...68-77? :yes: :no:
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
No....'68-'72. The '73-up brake pedal assemblies are completely different.
Comparing Clutch/Brake Pedals and Brackets
rjewkes
Post by rjewkes »
And on the boosters bolting right up from 68-77 it is only true if you have the matching brackets as the 73 and up slowly have a backwards pitch to them where the booster mounts to the brackets. I went through finding the correct booster becuase of this last year. i have the 73 up brackets from a '76 so the 68-72 booster points horrably towards the ground and the bolt spacing from left to right is off by 1/4".
