A say GM is out as well because of the price, but if you can afford a duramax, they are good reliable trucks.
Dodge has the best diesel motor, but the tranny can be a weak point if an auto. What I don't like about them is the chassis. Electroics and interior of earlier models (pre2004) are crap. They also did not have a true crew cab until this year, if you are looking for one of those.
I like the Fords best for the overall good package. My first was a 97 stroke with a 5spd and it was good. They can be made to have more hp over the stock 225 with some work. The 4spd autos in those trucks were considered weak, but if you are just towing once in a while they will be fine with routine maint. The superduty's with the 7.3s were a bit strong since they came with intercoolers and more hp from the factory. 250 with auto and 275 with a manual if that says anything. Again the autos were fine for moderate towing and occasional use.
The 6.0s have been notorious, but I have had 2 with good success. The earlier models 03/04 had the most problems and 05-07 got a bit better. Main issues were EGR and headgaskets that can be fixed to not fail. They have great trans. and good power in stock trim. I have a ton more info. on them if you want to get with me.
The 6.4s are good but have two main problems, the emissions junk and horrible gas milage because of it. The emissions stuff can get clogged and cause the truck to lose power and even more MPGs.
Just to be clear the Fords prior to the 6.4 had the HEUI hydraulic of electric fuel injection. The only time I broke down in the 97 was when the high pressure oil pump went out. It was at around 160k when it went and cost about $1100 to fix. The 6.4 has the common rail injection system with piezo injectors. AFAIK they have been good. The new 6.7 Ford psd is supposed to be awsome from the reviews I have heard from those who can afford them, but I would never buy another motor that has less then 2 years on the market.
If you want to build the ultimate truck, get a Ford superduty, drop a Cummins in it backed with an Allison trans.
