F600 dash tak drives.
flywheel
Post by flywheel »
I hear a bit about this, Why don't people go get a dis out of a old truck? or convert a dit out of 60's chricraft? i have a 63 Chris craft with 2 427 Fe fords and they both have tak drives on them, no vac advance. but that should not be hard t fix. Anybody try this?
My truck is low cuz I am short.
bluef250
Re: F600 dash tak drives.
Post by bluef250 »
I think both the heavy truck (361) and 427 dizzies are different than FE.
flywheel
Post by flywheel »
I might be on to somthing with this boat distributor. I will take pics,
the Ft distibutors will not fit in the Fe engines. that is why the cable drive tachs arent a good choice to use in the light duty trucks most are restoring/building.
averagef250
Post by averagef250 »
Because the mechanical drive tachs don't go high enough for 99% of engines. They were made for the 4000 redline of the truck motors.
1982 flareside
Post by 1982 flareside »
Dont hold it to me but i think boat motors run backwards. NOT FOR SURE THOURGH.
Jeremy
Caseys71
Post by Caseys71 »
1982 flareside wrote:Dont hold it to me but i think boat motors run backwards. NOT FOR SURE THOURGH.
I think that that is the case in a dual engine equipped boat, and in that case only one turns opposite though. Atleast that is the way I remember it :lol:. Not telling you that you're wrong figured I'd put in my :2cents:!
Casey
hazelnut
Post by hazelnut »
Twin inboards engines have one engine thats turns backwards, to use the dizzy you would only have to change the drive gear.
