Hello
I am installing a pertronic Ignitor electronic Ignition and a Flam thrower coil on my truck. I don't think it has a resistor. (does it?) It has a 390. Usually starts right up, but every 6th time or so is a very hard start. Also replacing the fuel pump. Just rebuilt the carb.
Thanks for any input. Mancar 1
68 Ford 250 Camper Special
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: 68 Ford 250 Camper Special
it has a resistor wire. i think you might have to put a resistor in there. but i am unsure on those setups what it takes to install them.
