my much to restore my 69 f250 truck
sacramento_ford
Post by sacramento_ford »
well, im kinda into this hot august nights i seen on you tube. i would love to restore it, how much am i looking at front to back, trucks pretty much complete ,chrome is duddy, id like to replace all trim,good new paint. tires are ok , replace brakes and rear axel, windows trim and some interioir, interior i can do myself, id like frame coated, to me the most importany part is a good tranny and bitchen engine with headers with a tri power set up, ,,,
its a 69 with top and bottom trim package. dont want a show car, but good enough for car shows.
69rangerf100
Re: my much to restore my 69 f250 truck
Post by 69rangerf100 »
so for on my resto i have spent about 1500 on misc. parts im looking at about 2500-3500 for the paint job about 400 for the seat being redone. so modestly i would say atleast 4000
David
Ranchero50
Post by Ranchero50 »
$10,000 usually covers it...
70_F100
Post by 70_F100 »
Ranchero50 wrote:$10,000 usually covers it...
:yt:
sacramento_ford
yeah it is hard to sell , as much as i hate being stuck at my sisters house, i can easil get 1500 for my truck,
its virtually imposible to sell, emotional attach ments are impossbile to break
1971ford
Post by 1971ford »
Restoration is way too broad of a word.
Restoration as tear down to BARE frame rails, and buy all new parts, or restoration as repaint, some new parts, cleaning it up.
For a real restoration, i'd say over 10,000 easy.
-Ryan
69rangerf100
i have to agree with ryan and everyone else a full on resto is gonna be costly. i made aspreadsheet today for all the parts that i have bought so far that totalled 2500 and the list of parts to buy totalled another 1500-2200. and this does not include paint or the rebuild on the tranny or the engine. not trying to get you down any.
David
1971ford
Post by 1971ford »
Come to think of it... you're in sacramento, you're probably 30 minutes away from me.
I have a restored '69 f100 2wd frame that I need to get rid of. Stripped to bare metal and coated in POR-15. I have stripped/POR-15'd rear springs with new bushings to go with it and a restored underbed tank/skid. That would be a good start for your restoration. I want practically nothing for it....
-Ryan
flyboy71
Post by flyboy71 »
:yt: and thats just money spent on the tools to get started.
-Jeff
mark F-100
Post by mark F-100 »
just to let you know I'm doing a frame off rest. on 68 F100. brakes bearings seals master cyl. lines bushings 2000.$ motor 4000$ tran rebuild 600$ tires@rims 1500$ paint6000$ Good luck on yours and have fun.
69rangerf100
mark F-100 wrote:just to let you know I'm doing a frame off rest. on 68 F100. brakes bearings seals master cyl. lines bushings 2000.$ motor 4000$ tran rebuild 600$ tires@rims 1500$ paint6000$ Good luck on yours and have fun.
wow 2000 is alot for the brakes. i got a disk brake setup including suspension for 125 and spent 175 on new components for the setup and i would new lines for 190.
David
mark F-100
2000$ alot for brakes should have been more clear all new drums,flex lines,pads hardware axle seals@bearings,diff pod seal,I beam bushings emg. cables sorry about that
bluemoose
Post by bluemoose »
Glad I'm not up there. I replaced everything but the rear drums (had them ground).
Rear brake kit
Shoes
rubber hoses
Seals
Cylinders
Front drums
shoes
brake kit
cylinders
rubber hose
bearings
Total was about $450.
I guess the price would go up significantly if I were to buy prebent brake lines, but coated line runs about $25 plus the couplings. I didn't need to replace emergency brake cables.
I am into my truck, including purchase price to about $4000. This includes all the body parts needed to do the job, suspension, brakes. I have not started on the engine, so I don't know what that will run. I figure that the small stuff, interior and wiring is where the price tag will go up quite a bit. It depends on whether you can make the stuff you have work by cleaning it up or if you have to buy new, and what type of resto you are doing. To bring it back to original the nickel and dime stuff will be a real killer.
My plan is to do the entire body and engine, get it back together and then do the little bits to give it a real clean look over the next several years.
Of course this is all without paying the labor (me). If you need to have this done for you I would figure double and then some. :2cents:
Moose
