So I decided i would build a cage for the front of my 6x12 trailer. The cage is 54" tall and 80" wide. The cage part is 24" x 24" x 80." The whole thing sits atop the 12" tall side rails on the trailer and is secured with grade 8 bolts. The hinges I used for the door are tamper proof.
Today I finished welding up the frame for the cage. Everything was nice and square until I decided it needed more welds. Should have left it well enough alone.
The door bows in along the bottom now after I welded the hinges to it. Also has a bow at the top where I welded up the hasp for the pad lock.
The legs are twisted at the bottom from side to side so the look like \ \ from the top. The odd part there is they twisted equally from front to back. So that at the front of the cage across the trailer you get 80.5" and from the back of the cage across the trailer you get the same measurement.
The cage is mounted to the trailer with four grade 8 bolts.
As far as putting the mesh on the frame of the cage...
That part went well. The only hick-up was I miscalculated how much I would need to box in the two 24" x 24" ends. I had to use two pieces to do those on each side. 19" x 23.5" and 5" x 23.5." The largest scrap pieces I had were not wide enough to get it in one piece.
After all that I painted it semi-gloss black to match the trailer.
