I have a 1969 f-250 and when it rains water leaks down both corners inside the cab, which has caused the floor board to rust out in some areas, any ideas where the water is coming in from?
Lou
leaks
Re: leaks
probably from the cowl areas. wehre the cab and cowl are put together at. remove the vent on the drivers side and clean the leaves and stuff out of there so maybe the water will flow out faster. on hte passenger side you have to remove the heater duct fresh air supply duct to clean the stuff out of that side. check out this thread to see how it is all put together. http://www.fordification.com/forum/view ... ilit=+Dash
- amishbuggy
Re: leaks
On my '70 F-250 I had water coming in those two spots from the drip edge and from the old marker lights.
