Can do will probably start by spot fixing some of the rust I have neglected to remedy 1st then on to the suspension, plus I have not found a donor yet. Did find an alturnative to having to add a secondary rail as 23boysdad did. Nothing wrong with the way he did it looks fine works great. Looking at his pics you can see the rack pretty good and I would like to have the ground clearance and let it be less visible. Yes I know if I run a 31" tire the distance from the rack to the ground will be the same as the I-beams to the ground now. I just like it tucked up under the truck better. I found a 3" lift for the panther front end, looks like the DONK guys aren't to found of how it's made as they don't offer as many lift options for it as the others? If the 3" lift works I can add a 2"-1 1/2" spacer under the rail and have it setting just where it is now. Spacer Kit 3" Lift 03-05 Crown Vic, Marquis, Towncar $195.00 http://universalcarlifts.com/product_in ... ucts_id=45BobbyFord wrote:Nice. Make sure you post progress pics of those suspension mods
