im confused with my truck
my truck has no custom cab logos,yet it has the better heater and a drivers door armrest,witch as i undertand are CC only
it is a 67 merc 100
it is a 67 merc 100
- Mancar1
Re: im confused with my truck
How about a pic of it. Mine is a 68 Ranger Camper Special. I'd like a Merc. ![Cool 8)](./images/smilies/icon_cool.gif)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
so is mine a CC or a standard cab with options?
to tell what you have. go to http://www.martiauto.com and order the build sheet.
- mk
If you haven't got chrome trim on the doors and have the silver metal instrument cluster bezel you've got a base model. Someone probably added the armrest and the deluxe heater was a stand-alone option; it wasn't part of the custom cab package. Does your truck have the painted grill?
For more info on Mercs, check out this thread:
mike
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
~Will Rogers
the grill is painted white
and you can see the armrest was there from the start cause it isnt there anymore and the spot where it was isnt as faded as the rest
- mk
It was obviously checked off on the original order form then. The c/c package had chrome on the doors, around the headliner, windshield and taillights, aluminum grill and a chromed plastic cluster bezel in addition to a couple of other minor things. Check out the literature section for the '67 brochure pics.
mike
mike
~Will Rogers
~Will Rogers
- mk
After '66, the Mercs didn't have any special options or packages the Fords couldn't get except for the outside letters and tailgate. There's a lot of strange combinations of options though. My own '68 custom cab came through with no radio, chrome bumper or even the extra gauges; it has the idiot lights even with the chrome plastic bezel.
mike
mike
~Will Rogers
~Will Rogers
- Mancar1
1967mercury100 wrote:so is mine a CC or a standard cab with options?
CC
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- mk
Mancar1 wrote:1967mercury100 wrote:so is mine a CC or a standard cab with options?
CC
mike
~Will Rogers
~Will Rogers
what is the better heater ? i got a 65 cc and the heater aint nothing spiecal two speed fan mabey??
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
- mk
They both have the two speed fan I believe. Having the deluxe heater means you don't have to get into the engine compartment to open the hot water valve to the heater; you can do it from the dash control.
mike
mike
~Will Rogers
~Will Rogers
