OT: Side draft chimney for furnace
flyboy71
Post by flyboy71 »
Well the weather here has gone from near triple digits to almost fall and I need to figure out if Im gonna heat the garage. I acquired an old working mobile home furnace last spring and Id like to temporarily install it without cutting a hole in the roof. Has anyone vented an oil furnace through an insert in an existing window using a side draft flue or something?
-Jeff
Re: OT: Side draft chimney for furnace
i will start out by saying that newer mobile home nat gas furnaces have both the intake out out take at the same place and they take a special pipe to be hoooke dup correctly. i dont know how hot a oil burner mobile homes furnace flu gets. so i dont know how to direct you on how to install the exhaust.
Mancar1
Post by Mancar1 »
Yes you can do it, just use the proper vent piping.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Ranchero50
Post by Ranchero50 »
Natural gas yes, oil I would call the building inspectors and talk it over with them. I'm pretty sure you need to do a chimney due to the chimney heat and carbon monoxide, triple wall to 24" above the peak of you roof. Cost me around $480 in materials. Single wall to the ceiling height, then an adaptor, then 8' of triple wall with a roof penetration, guy wires and a cap. Only took a couple hours to do once I read the instructions about ten times. Most restrictions are combustable within 8" of the triple wall, 24" within the single wall.
Google Metal-fab inc
At the end of the day it was money well spent, put the thermostat next to the unit so I can keep the garage above freezing and it warms the 24x28x8 in a matter of minutes. My furnace is a Tempstar 105 kbtu. Mix 1 gallon of waster oil pre 20 gallons of heating oil. Used around $200 last year.
Jamie
