body swap
body swap
OK well I bought a 73 highboy a couple months ago. I was going to go to a bump style body. Well this weekend I came up on a 2000 f250 body from a repo. I can get the body for the cost of going to get it. It's a standard cab long bed Superduty 2x4. Anyone have any input or how hard this swap may or may not be.
- fordamericana
Re: body swap
Are you talking about putting a 2000 model body on an older chassis?
I likes My FE I does...
- Caseys71
Re: body swap
fordamericana wrote:Are you talking about putting a 2000 model body on an older chassis?
Casey
- 1971ford
Re: body swap
You would have to be VERY skilled at welding/fabricating and would have TONS of headaches to deal with by doing that...
I say put a bump body on it or leave the dent body on it.
-Ryan
Re: body swap
Well a bit of an update. I went and took some measurements and it wont take to much. Some custom body mounts on the frame and redrilling some holes here and there. I didn't think it would take to much but wasn't sure. I am going to get the body this weekend if all goes well. Depends on how fast I can get the combine to cut beans.
- fordamericana
Re: body swap
Well, send us pics if you can. I think I'd like to see this...RTG_RACING wrote:Well a bit of an update. I went and took some measurements and it wont take to much. Some custom body mounts on the frame and redrilling some holes here and there. I didn't think it would take to much but wasn't sure. I am going to get the body this weekend if all goes well. Depends on how fast I can get the combine to cut beans.
Re: body swap
You know everytime I try doing that I get into what I am dong and forget to take pics. I don't think this will be to hard because this was a WT version. It also had a manual. SHort of access for the transfer case the cab should go on without much fuss. Well I hope.fordamericana wrote:Well, send us pics if you can. I think I'd like to see this...RTG_RACING wrote:Well a bit of an update. I went and took some measurements and it wont take to much. Some custom body mounts on the frame and redrilling some holes here and there. I didn't think it would take to much but wasn't sure. I am going to get the body this weekend if all goes well. Depends on how fast I can get the combine to cut beans.
