wheel question
460F100
wheel question
Post by 460F100 »
these are on my 70 f250 16.5 alloy spoke. the valve is behind the spoke who makes these? i need one more to make a set of 4. the 4th wheel was damaged and thrown away by the original owners.
2006 f250 superduty ccsb-4x4-auto-6.0l
2002 f250 superduty ccsb-4x4-auto-bad 5.4l
1972 f100 longbed-4x4-460-4spd
1972 f100 longbed-4x2-302-4spd
1971 f250 longbed 4x2-360-auto
1970 f250 camper special-360 auto
1985 v.w. golf diesel
1989 ranger
1993 mustang lx 5.0l
2001 mustang bullitt-dhg #1782
1967 chrysler newport 2dr fast top
FORDification
Site & Forum Admin
Site & Forum Admin
Re: wheel question
Post by FORDification »
They look to me like common aftermarket white spoke wheels, manufactured by a dozen different companies. I'd take one of the wheels off and see if there are any identifying marks on the back side, but more than likely you'd have to remove a tire to see those.
trukcrazy
Re: wheel question
Post by trukcrazy »
460F100 wrote:these are on my 70 f250 16.5 alloy spoke. the valve is behind the spoke who makes these? i need one more to make a set of 4. the 4th wheel was damaged and thrown away by the original owners.
[ Image ]
If they are aluminum, your best bet would be like Keith says. Remove it and look for the manufacturer somewhere on the rim. Good luck. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
basketcase0302
Re: wheel question
Post by basketcase0302 »
460F100,
These guys have gotten me out of a bind more than once with some hard to find valve stems an/or tubes:
http://patchboy.com/mm5/merchant.mvc?Sc ... ore_Code=P
Prestige also has a fairly large selection of them:
http://www.prestigewheel.com/RetailValveStems.asp
I just went through this on my Alcoas, you might need to measure the valve stem opening (removing an existing valve stem) to get the correct diameter. :thup:
I wound up taking 90 degree stainless stems and "tweaking" the bend out to about60 degree to work for me.
ScreaminZ
Re: wheel question
Post by ScreaminZ »
I think he's looking for the wheel, not the valve stem. He mentioned the valve stem because the placement was unique.
460F100
Re: wheel question
Post by 460F100 »
they are deffinatly alloy. i was just wandering if anybody has seen this type of wheel and maybe who made them. did not know if this type was one company specific or differant comapnys made this type. i did have the wheel off before and did see anything inside the wheel. someday i will pull one off and look better before i break it down.
1989 ranger
averagef250
Re: wheel question
Post by averagef250 »
16.5's are obsolete. Tires are very hard to find and soon to be non-existant for them.
