Wow! and I thought I have a heavy duty Butt guard. Wanted a CS with the bed side storage but mine will do.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Troy
I came across a f600 in the JY today, 1970 with a 390 and some monster disc brakes on the front. I have never seen a f600 bumpside. I'm thinking of buying the doors of it.
the guy i bought it from want $500 but took $250 when i showed him the holes in the cab mounts and inner fenders. the thick undercoating is probably the only thing that saved the rest of it. inside the bed is a little beat up from hauling coal but the tailgate is straight and not rusted thru. the last time it was licensed was 03 so it sat for 6 years. i should not have started it without checking that tank out first. as you can see what happens when running old gas. 15 pushrods and 2 fuel pumps later. the 114k 360 runs good and the auto trans shifts good. no blue smoke just some black from carb issues. looking at the bumper looks like it will slide back 3 more feet.
