OT Guessing game Grille interchange newer trucks
casting number 4L34-8200-cz what year did it come off of and what years wil it fit. it has two brackets that bolt to the hood. and then some studs that are at the top and probably bolt to the hood also. i have a slight idea. but i wanted more opinions on what it also fits.
- TheEskimo
Re: OT Guessing game Grille interchange newer trucks
I am sure it would fit the 04-07, couldn't tell you for sure what year it came off of.
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
- Mancar1
Looks the same as the one on the 06 I had.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
its for an f150 i believe 04-07
