Headlight question
TexasTruck72
Headlight question
Post by TexasTruck72 »
Today,I noticed one of my headlights has burned out, the low beam to be exact 'cause the high beam part still works. Since purchasing my bump, I haven't had to replace a headlight yet.
Is there a lot to it(in terms if difficulty)? I wouldn't think so.
Any tips or tricks to removing it?
Does anyone know of a good brand of light or part number to replace it with?
Thanks,
TexasTruck72
Jack
1943 Ford GPW Jeep(sold)
1972 F-100 Custom
1976 F-150 Explorer
1996 F-150 Eddie Bauer ed.
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Headlight question
Post by FORDification »
It's a standard 3-prong high/low headlamp, used on virtually every American car/truck. Any parts store (or even Walmart) will have those.
To replace, just remove the 4 screws holding the headlight door, then another 3 to remove the lamp retaining ring. Then just pull the headlamp forward a little and unplug it. Installation is the reverse.
when gettign a new one. either replace both o fthem so they match. ie: halogen or standard. or match the new one to the old one as far as type. it will shine brighter on one side if yo uhave a halogen on one side and a standard on the other side.
TexasTruck72
Thanks Keith and Fordman!
:fr:
Jack
1972 F-100 Custom
1976 F-150 Explorer
mlheppl
Post by mlheppl »
just make sure you're unscrewing the headlight retaining ring and not the headlight adjusting screws or your headlight will end up out of adjustment.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
cdeal28078
Post by cdeal28078 »
Before I went with the ebay crystal headlight swap I always swapped both at the same time. If I didn't the other one would burn out with in a month is seemed. I guess since they both burn the same amount of time they burn out pretty close to the same time
If you want brighter lights look up the relay mod for the head light. I think it is called Brighter lights.
I did that and added the halogen type bulbs and man what a difference.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
