so i started off with a 1970 f-100 shortbox 2 wd. no motor or tranny but i got a 460 and c6 in the deal. well after a short time i procured a 1979 f-150 4x4 shortbox with a built 429, np435 4 speed, 205 t-case, 1/2 ton with a 4" lift. so here goes the body swap process...
1970-69-79 f-100
Re: 1970-69-79 f-100
strippingg bodies
removing factory fuel tank in favor of the frame mounted tank
well the 70 is stripped
starting to strip the 79. i decided to strip the frame and paint it. i also opted to undercoat the body of the 70 before i set it back on the frame.
last pic i have for now. currently stripping the interior. i have already welded holes in the floor. i am also stripping and finishing the front inner fenderwells and the core support. i'm using por-15 to spray everything. im waiting for my herculiner to get here so that i can line the inside of the truck and the underide and inside of the bed. still have to move the rear springs forward to match the wheelbase. game plan is truck on 35's
- FormerMarine1981
Looks good, can't wait to see more progress.
i havnt had time to get back to the truck....im going through a custody battle and i purchased the house across the street from where i was working on the truck. so here shortly after i finish my 72 bump to get it running i will be back on this truck full scale. in the process tho i am aquiring parts to finish the interior....updates to come including my new intake hi ram dual tunnel ram....
- fbomb100
wish all the luck with every thing
