fuel tank selector switch
Mancar1
Post by Mancar1 »
Getting ready to take the 68's fuel tank selector switch apart and clean it. Figure it may be why I get a partial reading on both tanks. When I fill them the main one reads just under 1/2, and when I switch to it the aux. reads about the same. Once each tank gets down under half a tank the gage reading for both tanks works all the way to empty. Any tricks to taking off the switch, or is it simple like any other switch removal?
My 68 and my wood working sure help keep me in a good mindset.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: fuel tank selector switch
the problem isnt in that switch. it is possibly the gauge in the dash. or an adjustment to the ipvr on back of the instrument cluster. here is a link to test it.
the problem isnt in that switch. it is possibly the gauge in the dash. or an adjustment to the ipvr on back of the instrument cluster. here is a link to test it. http://www.fordification.com/tech/fuel- ... -units.htm
Mancar1
Post by Mancar1 »
Thanks fordman, I will check that out.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
bluef250
Post by bluef250 »
Check this post. Sometime the contacts get dirty and need to be cleaned. The switch comes apart easily. Just watch for all the small parts. Actually, the switch has 2 set of poles and by switching wires you may be able to use the other set of poles.
http://www.fordification.com/forum/view ... uel+switch
Mancar1
Post by Mancar1 »
bluef250 wrote:Check this post. Sometime the contacts get dirty and need to be cleaned. The switch comes apart easily. Just watch for all the small parts. Actually, the switch has 2 set of poles and by switching wires you may be able to use the other set of poles.
Thanks for the pointers.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
