pitman arm
Moderator: Doug Comer
- lobuck76
pitman arm
what other years will swap over to a '69 highboy f250? I need to chase down a pitman arm and draglink. I located a doner truck '78 or '79 half ton. I'm wondering if the front end parts will swap over. The doner truck also has power steering.
'71 F-100
- 460 crew
All 67-77.5 4x4 F250 manual box pitman arms and drag links will work. The power assist draglinks are a little different but are a bolt up.
