Need help with corvair
amishbuggy
Post by amishbuggy »
Can anyone help me out with how to remove this ignition? It's from a '65 Corvair Monza Spyder. I've tried inserting a rod in the hole but I'm not feeling any sort of release.
Thanks
Pat
Mancar1
Re: Need help with corvair
Post by Mancar1 »
I used to have a 64 Turbo charged one back in the 60's. Ran away from a lot of V-8s on the open road.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
i think gm is like other switches. you have to turn it to acc to get the key cylinder to come out. when you push the pick in there.
amishbuggy
thanks fordman, I'll try it when I get home
70_F100
Post by 70_F100 »
fordman wrote:i think gm is like other switches. you have to turn it to acc to get the key cylinder to come out. when you push the pick in there.
:yt:
amishbuggy
I can't get the switch to the lock position (no key), I've tried the others but am having no luck with removing it. I guess I'll have to take it to a lock smith so I don't bung anything up.
