Did I work her too hard
FordRocket72
Post by FordRocket72 »
I am doing a job that required 3/4 cubic yards of concrete sand for paving stones. After leaving the rockery I thought I might have worked my old Ford too hard. She wouldn't go more then 30mph and I was worried. Did I work her too hard? At least I know what my truck will look like if I lowered her.....
BRUTUS_T_HOG
Re: Did I work her too hard
Post by BRUTUS_T_HOG »
doesn't look too low. you have a 6cyl? chances are that the engine/gears just weren't powerful enough to haul the load fast
ASE Certified Technician
FordRocket72
390, with automatic.
Mancar1
Post by Mancar1 »
390. How does it run? Tranny work ok? Sounds like high miles, and some work is needed. Even with a heavy load, if things are working right that 390 should move out with no problem.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
GSequoia
Post by GSequoia »
I hauled this in my F250/390/C6/4.10:1 no problem.
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
Mancar1
Post by Mancar1 »
GSequoia wrote:I hauled this in my F250/390/C6/4.10:1 no problem.
[ Image ]
That's what I'm talking about. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
onetuford
Post by onetuford »
My brother had a 72 f100 with a home-made dump box on it and hauled three yards of black dirt with no problem(360) except the axle was hard on the bump stop.
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
AlleyCat
Post by AlleyCat »
I'm with Mancar1. You're truck prolly needs some attention. That 390 should move that with no problem.
Clay
flyboy2610
Post by flyboy2610 »
The 390 builds it's power higher in the powerband than a 360 does. The 390 is a sport engine, the 360 is a truck engine.
You were trying to use a racehorse as a draft horse.
FLATBEDFORD
Post by FLATBEDFORD »
I often haul 5000lbs of firewood, gravel or dirt with my 360 powered F350. If the 390 was struggling it may have a problem. Do you know what ratio the rear is?
My Photo Gallery
Mancar1
Post by Mancar1 »
flyboy2610 wrote:The 390 builds it's power higher in the powerband than a 360 does. The 390 is a sport engine, the 360 is a truck engine.
I'm on my 3rd 390 over the years, in pickups, never had a problem with the pulling, hauling, nor the racing. :)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Post by Mancar1 »
A truck 390 is not a racehorse unless one makes it so. :thup: Thats my story, and I'm sticking with it. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
nevrenufhp
Post by nevrenufhp »
BRUTUS_T_HOG wrote:doesn't look too low. you have a 6cyl? chances are that the engine/gears just weren't powerful enough to haul the load fast
Is that because a 300 is weak? :hmm:
Here's mine with a little 6 banger hauling around 2000 pounds in the bed, and it did amazingly well. I even got on it to see how well it would get to 55mph. I couldnt stop too well, but that's a given.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
Mancar1
Post by Mancar1 »
:lol: :yt: My 81 Ranger had a stock 300 six. Good truck, good motor. Could haul, and pull within its limits. Sure as heck couldn't pull like a 390. Not even close. I believe 1981 was the last year of the full size Ford Ranger. When we got our 27' Streamline I did pull it the 6 miles to our place with the 81 Ranger. Did the job, but it did strain it a lot. :lol: I should have used Dad's 78 Chevy with the 350, but he had said my Ford 6 couldn't do it. It did, but it shouldn't have.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
FLATBEDFORD
The 300 six will move anything as long as you are not in a hurry. I have owned Ford trucks with the 300 six, 351, 360, and 6.8 V10. Aside from the V10, and excluding fuel mileage, I'd say the 360 is the best truck engine. The six had torque like crazy, the 351 needed some RPMs for power and the 360 has the torque of the six and the HP of the 351. The V10 blows them all away in power and economy.
My Photo Gallery
