I need tires!
CharlesT
I need tires!
Post by CharlesT »
Where can I get tires for my 1972 F250?
Front size is 7.50 - 16 LT
Rear size is 12 - 16.5 LT
Thanks!
1972 Ford F-250 Custom "Seymour"
jbohall001
Re: I need tires!
Post by jbohall001 »
The tire shop, duuuuuhhhhhh. :) check out tirerack.com
Vi hilser til Day
Vi hilser sønner Day
Vi hilser the Night og hennes døtre
Se på oss nå, med myke og ømme øyne
Velsign oss som sitter her
Vi hilser gudene
Vi hilser på gudinnene
Hilsen til deg; hellige Earth
Gi oss en gave av kunnskap og visdom
og la oss få hender som kan helbrede.
CharlesT
Re: I need tires!
Post by CharlesT »
I want to look at different tire and compare them. Need to find a good tire.
jbohall001
Re: I need tires!
Well, I find tire rack is good for that as well
Vi hilser til Day
Vi hilser gudene
Mancar1
Re: I need tires!
Post by Mancar1 »
Have you thought about 16 instead of 16.5 on the back?
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
CharlesT
Re: I need tires!
Post by CharlesT »
What would be the advantage?
CharlesT
Re: I need tires!
Post by CharlesT »
sorry, I'm an idiot. There are three spaces e.g. 205/55/16. What goes where for the 7.50-16?
jp2005
Re: I need tires!
Post by jp2005 »
Im not sure where you live, but check craiglist there are usually pretty good deals on there. If not discount tire has good prices for new stuff.
GSequoia
Re: I need tires!
Post by GSequoia »
You're not goign to find new in those sizes unless you go to some Super Swampers or something (yuk for highway!). The last 16.5 I can find in a good road tire is 9.5 x 16.5 by both Firestone and Cooper. My truck needs tires and I'm deciding now whether I'm going to get a set of used 16" steel wheels and go 16" or just get the set of special order 9.5 x 16.5 tires, this time it will break out even financially but I'm sure by the next time I need tires I'll have to go 16.
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
GSequoia
Re: I need tires!
Post by GSequoia »
Edit: I just re-read it and saw that you've got 16" wheels up front. If they're original they're probably split rims (the wheel rim on the outside comes off). You'd be hard pressed to find a shop that will touch them and are best off replacing the wheels with one piece wheels.
Mancar1
Re: I need tires!
Post by Mancar1 »
I went from 16.5 to 16 , lot more to choose from and you save on the $$$$$. I like to run the same size front and rear. My 68 is a daily driver, and the tires last a lottttttt longer when you can rotate them. To each their own :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
CharlesT
Re: I need tires!
Post by CharlesT »
Best case scenario, I'd like to get new wheels (rims) for it. What is the bolt pattern?
Mancar1
Re: I need tires!
Post by Mancar1 »
Your truck, what is it? F-250, it should have 8 lug. (8 X 6.5) Tire/wheel stores will know what will fit.Online, just enter your model of truck.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DuckRyder
Re: I need tires!
Post by DuckRyder »
http://www.cokertire.com/
May have something for you, although you definitely need to figure out what is up with the wheels and make sure someone has not put 16.5's on 16" wheels or vice versa...
You also might find:
https://store.cokertire.com/faq/tire-questions.html
and
http://www.tirerack.com/about/techcenter.jsp
Helpful...
eggman918
Re: I need tires!
Post by eggman918 »
the last 3 sets of tires I have run on the Filthy Beast were PepBoys 2 sets of there all-terrain and the last set mud-terrain,I do not run on the highway as much now.
I always get the road hazard and at least here they are good at honoring it.I cannot say anything bad about them :2cents:
Steve.
