Where would i find one of these to fit my 390?
- rjewkes
Is this something that comes in a cold air intake kit or is it a one of custom?
- taylor351
Re: Where would i find one of these to fit my 390?
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
1993 f150 351 4x4
1972 classic c10
- rjewkes
looks like i could use the '55-'95 universal kit 45x90.
- 1971ford
Or take a stock air cleaner housing and cut another hole in it and run a second tube intake deal and run some tube/hoses to the firewall. It work nicely if done right and look way more original
-Ryan
- HayHauler
1971ford wrote:Or take a stock air cleaner housing and cut another hole in it and run a second tube intake deal and run some tube/hoses to the firewall. It work nicely if done right and look way more original
No problem can withstand the assault of sustained thinking. -- Voltaire
- GSequoia
That's my plan as well. Stock air cleaner with two horns that have ducts to the firewall. I just need to get another cleaner one day to do the fab work to. I also plan to eliminate the carb pre-heater junk too. It would actually end up better than what was posted here because it wouldn't get hot air from the radiator, that setup is lacking a wall around the cone to keep the hot air out.1971ford wrote:Or take a stock air cleaner housing and cut another hole in it and run a second tube intake deal and run some tube/hoses to the firewall. It work nicely if done right and look way more original
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
- 68muscletruck
also my plan... but also living in freezing northern utah, in the winter you gotta pull the cold air hoses and use the heater ducting again otherwise you're like me and have all sorts of fun with your carb icing over from a big intake and the humidity1971ford wrote:Or take a stock air cleaner housing and cut another hole in it and run a second tube intake deal and run some tube/hoses to the firewall. It work nicely if done right and look way more original
