crash
crash
i crashed my truck tonight on the way home. it was a 88 dodge dakota. it had a utlity bed on it. and i just got it running good again. anyway i was thinking about soem personal stuff while i was driving and what i woul ddo abotu it. and i was going to fast and i missed the corner at the T intersection. i went over into the ditch on the other side. almost into a farmers field but i got caught in the ditch. the ditch was pretty deep. and it bent and twisted the frame on the truck. broke out the rear glass all over us. and jambed the passenger door shut. we had a small load of hedge in the back which made the truck heavier than usual. so that may or may not have helped. but anyway we had loggs in the seat with us. some went over the hood into the farmers field. i think we got everything picked up. it even broke my chain saw. that made me kind of mad. i took a picture of the truck but it was dark out. i dont know if i can lighten it up or not. i will post a better picture when i get back down to the truck. oh injuries. my wife go thit in the back with one of the pieces of wood. a small scratch on her knee. she says her arch of here foot hurts from jambing it into the tire compressor i had on the floor. i have two scratches on my forhead. possibly from flying glass from the rear. i also have both of my bird knucles scracthed. one is gashed into the skin. i am now feeling a slight headache. but i think that will go away. we were able to pull the truck out of the ditch even though it seemed high centered. in this first picture is when i got the truck 2 years ago. i had even replaced that messed up door.
Hemmi06
Re: crash
Post by Hemmi06 »
:eek: Glad you are here to talk about it!! Stuff can be replaced people can't!!
1971 F250 Camper Special
360cu with RV cam and 4v Carb
basketcase0302
Re: crash
Post by basketcase0302 »
Glad you're ok man, and that ya'll didn't get hurt worse!
It's so easy to get distracted anymore when driving. Bent the frame on the truck?! :eek:
mlheppl
Re: crash
Post by mlheppl »
Sorry to hear about your misfortune. Glad you and the Mrs weren't seriously injured.
Mike
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
Mancar1
Re: crash
Post by Mancar1 »
Sure glad the 2 of you are ok. Sorry about your truck.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DuckRyder
Re: crash
Post by DuckRyder »
Glad that everyone is not seriously injured and sorry about the truck...
When you see the truck in daylight, it may be better (or worse) than you think...
Re: crash
this morning my right hand is swollen behind both of my middle fingers and i really can't use it. so i wanted to leave this message with my left hand. i wont be doing much if any typing today. or maybe a few days. i had to sleep with my right hand in the air held up by the back of the coach. i'm going to make a phone call to try and find someone to help me button up my pants.
jzjames
Re: crash
Post by jzjames »
Get your hand checked out if you think it might be broken. Take care of yourself Fordman.
Re: crash
its not broken. just swollen. i wass using it last night for a awhile then it got to hurting. it may be ok. i finally took some ibuprofen and it is working on the pain.
390Nut
Re: crash
Post by 390Nut »
Glad you are still here to type what you are, Craig. Flying debree is always bad, but logs and a chainsaw?
Those could have made things a lot worse than they are. :eek:
`69 F100 390 4spd driver
danno
Re: crash
Post by danno »
Hey Craig, Glad you and the wife are OK,Don't worry about that brake valve till you feel better.I can put it on anytime
65 f-100 4wd short bed 360engine c-6 tranny
Re: crash
here is a bunch of pictures of where i was and where i landed at. as well as the truck and the load of wood i had with me. it isnt as bad as i thought it was. but it is still bad. the truck is probably driveable again. if i remove the bed. but i am not sure i can put the bed back on with the frame being bend downward.
Re: crash
here is the truck today.
Re: crash
a few more pictures of the cab and bed.
Re: crash
some of the damaged caused by the bed was because the front two bed mounts were already broken. i found that out when i put the larger gas tank in last week.
