1969 Color Code
1969 Color Code
I have a 1969 F250 Camper Special with a "D" color code. From info I have found, Ford did not use "D" color code in 1969. Can anyone help with this matter? I know from comparing this truck with a 1969 sales manual it was a very special ordered truck. Some of the things I have found out about it are: 1- 8'6" bed, 2- factory AC/Heat, 3- Trim from the F350, 4- Paint. It took 2 years to find the bed trim since Ford decided to take the trim all the down the bed and wrap it around to the tail light trim.
- Mancar1
Re: 1969 Color Code
My 68 doesn't have a exterior color code, but it has a M for interior code. The exterior color was a ordered color not offered as standard so it doesn't show on the door plate. Your D is most likely your interior code, and the exterior color was most likely ordered. Just my
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: 1969 Color Code
http://www.fordification.com/tech/VIN70.htm pinto yellow? 1970 or it coul dhave came from any other ford line up if it has a color code of D. special order emans they can pick and choose what they want the truck to be built as. your trim makes no sence to me. a picture is the only way for us to decifer what you have said about it.
