Help!
460 Custom
Help!
Post by 460 Custom »
Help! Ive recently acquired this (what i was told) is a early 70's Ford F-100 Custom with a Ford 460ci installed. I have searched the "Identifying '67-'72 Trucks" But could not match these pictures I have to any of the great info. Any help is appreciated!
71highboy
Re: Help!
Post by 71highboy »
looks more like a dentside.73 or later
BobbyFord
Re: Help!
Post by BobbyFord »
71highboy wrote:looks more like a dentside.73 or later
:yt: good eye. Where's the cab fuel filler hole and in-cab tank?
The Good Humor Man
Re: Help!
Post by The Good Humor Man »
Best way to tell is get the vin off the passenger side frame rail, and use the vin identifyer to narrow it down.
http://WWW.GoodHumorTrucks.Com
Re: Help!
it is a 73-79 . you cna tell by where the door hinges bolt on and the dent inthe body line behind where the door goes. also note the door sticker vin is gone. so probably the only vin you may find is the one on the frame and maybe one on the door if you are lucky. www.fordification.net
Caseys71
Re: Help!
Post by Caseys71 »
:yt:. It's a Dent-side ('73-'79) F-100, doesn't mean it's not an early '70s truck just that it's not a Bump. If you can get the VIN then here's a link to decode it: http://www.fordification.net/tech/vin.htm. Good luck with the truck! That 460 should be a lot of fun :wink:.
Casey
460 Custom
Re: Help!
To answer Bobbyford, the fuel tank, as of now, is located between the frame right behind the rear axle and the filler neck on the left side of the vehicle. And thanks guys, ill see about locating the VIN number off the frame.
460 Custom
Re: Help!
Also, im very new to the terms "bump" and "dentside". lol
1971ford
Re: Help!
Post by 1971ford »
bumpside (bump) - 67-72 ford truck, has a bump running down the side
Dentside (dent)- has dent running down the side. '73-'79
-Ryan
460 Custom
Re: Help!
Thanks guys! And yes, I havent been able to find the VIN yet as its been raining today, but yes, I went to look at the body parts hidden away in a trailer and it appears to be a Dentside
69rangerf100
Re: Help!
Post by 69rangerf100 »
either being a bump or a dent you have a good truck for a foundation. any help that you my need we are more than glad to help you out.
David
1971ford
Re: Help!
Post by 1971ford »
No doubt it is a dentside, you can clearly see the dent on the B-pillar. And it that isn't enough, it has a newer brake booster and the frame is different. Don't worry thought dentsides are almost as cool as bumps lol
-Ryan
71highboy
Re: Help!
Post by 71highboy »
1971ford wrote:No doubt it is a dentside, you can clearly see the dent on the B-pillar. And it that isn't enough, it has a newer brake booster and the frame is different. Don't worry thought dentsides are almost as cool as bumps lol
next best thing to a bump :yt: :hd: :woohoo:
ford4x4fun
Re: Help!
Post by ford4x4fun »
I thought a slick was the next best thing to a bump :?
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
forrestbump
Re: Help!
Post by forrestbump »
ford4x4fun wrote:I thought a slick was the next best thing to a bump
I Love em all! I've had Slicks, Bumps and Dents and they all were my favorites at the time I owned and cared for em'. As long as they're Fords, that's all that matters to me.
Larry
