How do you fix the fuel inlet ?
thefordguy
Post by thefordguy »
Hi, I bought a 1972 F350 Camper last week - I love it! It needs a lot of work, but it will be a lot of fun when it gets restored. When I pour fuel in the main tank it leaks immediately to the ground. The leak seems to be in the hose before it joins the auxillary tank hose. The problem is, there is a propane tank mounted right there. And I don't think the propane tank can be removed. I see that there seems to be a large metal cover over the main gas tank - if I remove this - would I be able to get access to the fuel line?
1969 F250 CS Ranger
1969 E300
ccryder2011
Re: How do you fix the fuel inlet ?
Post by ccryder2011 »
pics would be helpful
remember the key is to start what you finish....lol....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
edit. the aux tank filler hose goes between the bed and frame. that propane tank should be able to come off unless soemone welded it to the frame. in order to drop the tank to get at the hose without pulling the propane tank you wont be able to get at the hose either. the propane tank or bed will have to come off.
FormerMarine1981
Post by FormerMarine1981 »
The Main gas tank is the one behind the seat. The one under the bed is the Aux tank. Is the leak coming from inside the steel plate covering the gas tank under the bed or does it look like it's coming from one of the fuel lines?
Mancar1
Post by Mancar1 »
Pics would help, sounds like you may have the same setup as me. I have straps where the propane tank used to be. If it is the underbed tank I had a similar problem. Had a leak in the filler hose.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
thefordguy
yeah, it looks to me that the propane tank is welded to the lateral supports that run from side to side of truck. When I pour gas into the filler tube, it leaks almost inline with the filler tube, and when I looked underneath the filler tube pretty high up was wet with the fuel. Also, the fuel gage isn't working if I fill up the auxillary tank. Is that a sign that the gage is bad or is the gage only set up to work on the main tank. There is not auxilary gage switch under the dash.
1969 F250 CS Ranger
1969 E300
FormerMarine1981
I believe you are missing the switch for that tank. Is your filler neck above the bump line or below it? From what I have read it sound like the filler neck is the problem. Probably dried out and cracked around the hose clamp...
thefordguy
is there a way to fix or replace the filler neck from the throat opening?
1969 F250 CS Ranger
1969 E300
basketcase0302
Post by basketcase0302 »
FormerMarine1981 on Tue Jan 04, 2011 4:23 pm
:yt: You have to have a switch to go from from tank to tank sending units for checking the fuel, (not too hard to wire in if it's not there). And here's the fuel tank sending unit info:
http://www.fordification.com/tech/fuel- ... -units.htm
I just had to replace the float in my in sending unit, (and was very thankful I still have the in cab tank)! :pray:
thefordguy
Front Tank R&R for F350
Hi, I was wondering if someone could give me a few tips on repairing the front tank and snorkel. Does all work take place underneath the truck or is there some access from inside the cabin?
1969 F250 CS Ranger
1969 E300
Re: Front Tank R&R for F350
the in frame midship tank? whats wrogn with it? if it has holes in it it may need to come out to get repaired or replaced.
thefordguy
I've mentioned my issue in a previous thread - I've just been putting off doing this work cuz it looks like a pain. There is a leak somewhere from the snorkel to the tank. I'm not sure the best way to remove the tank since it has some kind of metal cover around it, and the propane tank is under the snorkel connection to the tank.
1969 F250 CS Ranger
1969 E300
Ranchero50
Post by Ranchero50 »
I don't think there is an easy way. My '70 F350 doesn't have the bed and you can access the fill tubing right behind the cab. My suggestion would be unbolt the bed and lift it up or drop the shield and tank.
Jamie
thefordguy
is the tank directly attached to the shield, or is it connected to the tank? I'm just curious about how heavy it will be when it comes off.
1969 F250 CS Ranger
1969 E300
Ranchero50
Usually manufacturers strap the tank to the frame crossmembers and then bolts the shield around it. Not sure if they did in these trucks though.
Jamie
