72 f100 4x4 Headliner project step by step
- bigred72
Hey everyone, Heres how i did it. First off before i ever started, i searched this site and got some good ideas and came up with a game plan. One of those ideas was from In ford we trust and his FRP headliner. My truck didnt have a headliner in it, so i went to the salvage yard and picked up 2 to use as templates. one was a '67 the other was a '72.
I then went to home depot and purchased a 4x8 sheet of FRP and some 3m super 80 spray adhesive. i then picked up 2 yards of black marine grade vinyl from a fabric store. The headliners i got from the salvage yard werent flat so i traced them on cardboard first and made a template. i test fit the template in my cab and it fit good so i traced the the template to the smooth side of the FRP(dont forget to mark the center screw hole) And started cutting..You do not have the required permissions to view the files attached to this post.
- bigred72
Re: Headliner project step by step, start to finish!
i Didnt like how slow the cutting was going
.. once i got it all cut out i i sanded the edges with 220 grit sand paper and checked it against the original... and did another test fit notice there are 2 screws with washers holding up the front then i screwed the center screw(not sure if these are factory, but theyre very handy
- bigred72
test fit with trim up...
Im kinda ocd and not knowing how the vinyl would go on i made a small version first... By the way i put the vinyl on the smooth side.You do not have the required permissions to view the files attached to this post.
- bigred72
Now on to the real one...
laid out my vinyl and trimmed up the edges a bit... i folded it in half and sprayed the vinyl and the FRP with 2 coats of adhesive and let it dry for 4-5 minutes(Instructions are on the can).. I then folded it back down and started smoothing with my hand from the center out. Be careful with this step cause you get one shot... that glue is stickyYou do not have the required permissions to view the files attached to this post.
- bigred72
I repeated the last steps to the other side...
)what i did was glue and fold the straight parts first and cut and tweaked the corners and cut outs to work with the contours(if that makes sense) i was trying to avoid bunching of the material and there you have it..the finished product... since i already did 2 test fits i was confident it would go up fairly easy and it did
Btw I did remove my rear view mirror and sun visors just so they werent in the way. I put up the trim, visors and mirror sat back and enjoyed the finished product. all in all it was more time consuming than difficult but i think preplanning and a lil ocd helps
Now comes the tricky part, this took some thought( i hate that
- bigred72
And Last but not least here are the installed pics...
I hope this helps anyone wanting to take on a similar project. if theres anything i can do to help please let me know.
- Hemmi06
1971 F250 Camper Special
360cu with RV cam and 4v Carb
- HRDROKN
Nice job!!!
Wow! Looks great. Thanks for the project thread! Now I know how to do mine. I was wondering how that would be done.
- stephen44
Very Nice - thank you - I will use this when time comes to do mine
thanks
Stephen
Stephen
- Fo-Mo-Co
That looks great. I was trying to figure out what I was going to do. This is perfect.
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
Henry Ford
That look sweet! You did an awesome job and all of your OCD paid off. I was going to do the exact same thing but in off-white vinyl but decided to stay with the stock look but your pics make me wonder if I should have gone your route! Thanks for the step by step and pics.
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
- bigred72
Thanks for all the kind words everyone. ive learned so much from fordification that i wanted to give back a little.
- fireguywtc
Re: 72 f100 4x4 Headliner project step by step
Great work!
Bill
At risk of being stupid. too late
What is 4x8 sheet of FRP ?
Eric
Richmond, Virgina
1970 F100 project?
1971 F100 donor
Richmond, Virgina
1970 F100 project?
1971 F100 donor
