1971 F350 4x4??
Moderator: Doug Comer
1971 F350 4x4??
Found a 1971 single wheel 4x4 that the guy SWEARS it is a 1 ton LWB. Not a 250, a 350. Is this possible? I'm not very 'up' on the 4x4 bumps. It seems to be in good shape and at a good price, but it is 4 hours away and I haven't seen any pics. Thanks for any help.
1968 F100 SWB Custom Cab, 360 3 speed 110,000 original miles, 2nd owner
1969 F100 SWB Ranger, family hand-me down in the process of a full frame off restomodification
1966 F100 SWB Custom Cab, 352 3-speed just pulled from a field on 6-9-11 a day before it was gonna be sent to the crusher
- averagef250
Re: 1971 F350 4x4??
Napco and others converted F350 2wd bumps to 4x4. They are neat, but not much of a 4x4 compared to a 250 4x4.
Odds are pretty good it's a F250 4x4. The VIN will start with F26 if it's an F250 4x4. A 2wd F350 will be F35, there was never a 4x4 F350 from the factory until 1979 and that was the exact same truck as a 250 with a higher GVW plate.
Re: 1971 F350 4x4??
Figured if it was a 1 ton 4x4 it was some sort of contraption not put together by Ford , Thanks for the info!
- Hawkrod
Re: 1971 F350 4x4??
There were F350 4X4's from the factory before 79 AND they are not the same truck as an F250. There are 78's and possibly 77.5's. They do have the same frame but have a Dana 60 up front standard where the F250 has a Dana 44 up front standard. They have other differences as well which is why they are so much money compared to a F250. Hawkrodaveragef250 wrote:Napco and others converted F350 2wd bumps to 4x4. They are neat, but not much of a 4x4 compared to a 250 4x4.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- averagef250
Re: 1971 F350 4x4??
You know your stuff so I'll take your word for it. I've seen dozens of 77.5-78 F-250 4x4's with 60 front ends, but they were F-250's. F26XXXXXX VIN . Seen just as many 79 F-350 4x4's, exact same truck, no difference whatsoever. Dana 60 rear axle, 1/2" wheel studs, but had F36XXXXXXXX VIN. Never seen nor heard of an F-350 4x4 built prior to 1979.Hawkrod wrote:There were F350 4X4's from the factory before 79 AND they are not the same truck as an F250. There are 78's and possibly 77.5's. They do have the same frame but have a Dana 60 up front standard where the F250 has a Dana 44 up front standard. They have other differences as well which is why they are so much money compared to a F250. Hawkrodaveragef250 wrote:Napco and others converted F350 2wd bumps to 4x4. They are neat, but not much of a 4x4 compared to a 250 4x4.
I've been around several governmaent/fleet ordered 60's and 70's crew and std cab F250 4x4's that came with closed knuckle 60 front ends. These were high GVW 250's, but got the 60 somehow.
- Hawkrod
Re: 1971 F350 4x4??
The Dana 60 was an upgrade option on many F250 4X4's but was standard on the F350. I have not seen too many 78 F350 4X4's but they are listed in the sales books and I have touched a couple of them. The later trucks are easy to ID because the door tag has the model year on it! I will wager that many people see the grille and assume it is a 79 but 78's had the same grille. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- Fo-Mo-Co
Re: 1971 F350 4x4??
I think 78 had the round headlights and 79 had square.Hawkrod wrote:The Dana 60 was an upgrade option on many F250 4X4's but was standard on the F350. I have not seen too many 78 F350 4X4's but they are listed in the sales books and I have touched a couple of them. The later trucks are easy to ID because the door tag has the model year on it! I will wager that many people see the grille and assume it is a 79 but 78's had the same grille. Hawkrod
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
Henry Ford
