1967 f250 side gas tank
Anybody know where I can find a filler replacment hose? LMC shows one for a 1971 will it work thanks for any help in this matter Chris
- forrestbump
Re: 1967 f250 side gas tank
First off...
and Glad to have you here!
I'm assuming you're referring to the rubber hose that connects the steel fill tube on the outside of your cab to the in cab gas tank?
If so, I don't have any first hand knowledge of LMC versus Dennis Carpenter, Etc. but I'll assume that the '71 hose should work.
When in doubt, call LMC and have them verify that it WILL fit before you buy.
If this hose is for your aux tank that's under the truck bed, than NO as '67 to '69 use a different hose than '70 to '72.
Larry
Larry
- Ranchero50
Welcome to the site, I would suggest removing it and taking into the local NAPA and have them see if they can order it. I ordered straight hose and it was less than $10 per foot.
Jamie
Jamie
