gonna check out a 67 stepside
my bro's found a 67 shortbox stepside thats been sitting for 15 yrs. dead 6cyl,dunno what trans (likely a 3 on the tree) supposedly has a good body ,but the things been in the middle of a blackberry patch with broken side glass for a long time...so i'm betting at least the cab floor and likely the cowl are rusted out
the guy wants $400 for it,but i think i can get it for a fair bit less ...we'll see ....i'm checkin it out on sunday
- basketcase0302
Re: gonna check out a 67 stepside
Cab alone would be worth that much IMO.the guy wants $400 for it
Good luck, let us know what happens!
- Mancar1
Sounds like it will be a good find. Pick some black berrys. They in season there? They are only a couple weeks from it here.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- guerra
How was it?? Did you get it??
1967 f-100 lwb 360/c6
well- that was a waste of time.
Total P.O.S. - rusty as all get out -it looked semi-alright till i checked it out- rotted inner fenders and rad support,,no side windows.moss growing on the mouse chewed seat (wasp nest in under dash,) ,holes in the floor,driprail (and roof) rusted thru ,door locks seized, dented hood,soft cab mounts,cab corners rotted right off... rusted cowl...rear fenders okay-ish ,box floor rusted thru,tailgate missing...the frame might have been usable but....i just left...even as a partes truck not worth bothering with even if he paid me to haul it outta there..
- cowbay
But other than that it was perfectWhateverman wrote:well- that was a waste of time.
- gregamorton
sounds like a good driver with a tuneup!
- stephen44
I bet an hour or two with the buffer and you would have changed your mind
thanks
Stephen
Stephen
- mk
Box floor rusted through? On a flareside?
Shortbox frames are pretty scarce up here...
mike
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
~Will Rogers
yup, and all along the bottom of the sides of the bed -you'd be rusted thru to with the amount of soaking wet composted god-knows-what that was in the box piled on you for the last 15yrs-mk wrote:Box floor rusted through? On a flareside?![]()
mike
yeah,shortbox frames are rarer than rocking horse poop but i'd rather spend my time hacking my existing frame shorter (if i ever decide i want a shortbox)than mess with a pile of trash like that nightmare....
when i entered the guys yard the truck looked semi-almost worth bothering with,but that changed in a real hurry when i started actualy looking it over....
the sad thing is,i remember that truck from probably not long before it popped the 6 that was in it,16yrs ago it was a pretty sweet ride
...for a short moment i almost felt pity on the sad old heap,but came back to reality when i realized how much work it would be to even attempt to ressurect the thing- and how nothing (and i mean nothing) on the truck was good enough to warrrant buying it as a parts truck...which i could hardly believe... and which kinda ticked me off,seeming as the truck was supposedly in "pretty good shape"
