CL find
champdog
CL find
Post by champdog »
68 F-100 LB 360
98 f-250 LT 4x4 SB Just sold it. It was a good truck.
flyboy2610
Re: CL find
Post by flyboy2610 »
That would sure come in handy to trim trees!
Ranchero50
Re: CL find
Post by Ranchero50 »
Heck, I'd buy it but it seems like it'd be a bit hairy without outriggers.
Jamie
Re: CL find
just need a chainsaw. mayeb it doesnt swivel and is just astraight up and down only. so they didnt see a need for outriggers. but outriggers are the way to go with something like that. if it doesnt swivel it is kind of worthless to cut down multipule limbs.
cdeal28078
Re: CL find
Post by cdeal28078 »
YOu could make money changing bulbs in parking lot lights also. The out rigger thing is true also. When I was in the Air Force I did runway lighting but also changed the bulbs in the street lights. If the bucket truck a line truck were busy we used the runway truck which had a 30ft wood ladder on a swivel. The swivel would lock but if that ladder was all the way up that little 78 Dodge D300 or whatever Dodge had for a 3/4 ton sure would do some swaying. It would put your stomach in your throat if you were not sued to it. If it was very windy and we had to change out the whole fixture or do something that would take some time we had a jack and some block and would block the bed of the truck up just enough to help with the swaying so there are some things you can do to help
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
AlleyCat
Re: CL find
Post by AlleyCat »
I've bucket trucks with short sections of chain welded to the rear spring retainer plates and the other end bolted to the frame. I was told it does help when the bucket is swung over the side.
Clay
