Many of them are if you have the right flex plate, bell housing and input shaft. IF you get everything except the flexplate from a 5.0 Mustang I would think that would be a pretty much bolt in deal except for the tranny mount and drive shaft. Fles plate will need to match the bell housing in tooth count and size and balance for your older 302.
A lot more out there know much more than me though so wait to hear from them
clint
Well i guess we will have to maybe change the trans mount maybe the drive shaft and go to the hydro type clutch. I think from 1980 on they went to this type of clutch in the trucks. Any more info will be very helpful.
My truck had the 4 speed and the drive shaft needed to be shortened and the cross member moved back aprox 4" the M5od uses the same slip yoke that a C4 uses,might be the same as 3 speed clutch is hydraulic but not too hard to retrofit.Hope this helps.
Steve.
