Happy_Camper wrote:Very clean! What a beauty! They are great looking cars.
Any plans for future modifications? Suspension and handling?
The shock tower brace is an awesome addition for structural support.
I'd highly recommend a few inexpensive upgrades (if you don't already have them):
* "The Club" steering wheel and brake pedal locking devices.
* subframe connectors with seat braces.
* reinforce the body mounts for the rear lower control arms
* SFI rated harmonic damper
* Green stuff brake pads, and slotted rotors.
And then for some real fun, add a set of adjustable struts and shocks (I really like the Tokico Illumina setup), some H&R supersport springs (great spring rate for a convertible), and M-M Caster Camber plates. Those additions will turn your car into a real corner carving speed demon.
Thanks all!
It already has welded subframe connectors and an SFI damper but not sure about the reinforced mounting locations. Here's a list that came with the car:
Motorsport 9 lb. supercharger by Powerdyne
GT40 turbo-swirl aluminum heads
GT40 upper/lower intake
1/2" phenolic spacer under the lower intake
70mm throttle body
73mm mass air
All MSD ignition w/ billet distributor, 6 BTM box, and Blaster coil
Motorsport aluminum radiator
Electric fan
Motorsport oil cooler
HPM strut tower brace
Summit battery relocation
Mac headers
1:7 rockers
Motorsport aluminum driveline
3.55 gears
2.5" stainless H-pipe w/ high-flow cats
2.5" Flowmaster cat back
Megabyte Jr. lower control arms
Motorsport HD upper control arms
Motorsport 190 liter/hour fuel pump
42 lb. injectors
KYB shocks/struts
Steeda 19 camshaft
UPR intake pipe
New stage 2 Spec clutch
Steeda Triax shifter w/ graphite knob
Welded subframe connectors
M/T drag radials 255/50-16
and yes...it is one helluva kick to drive!!!!
Patrick
To see more of my F100's:
http://www.cardomain.com/id/lowfat56
