warning flasher switch location
cookmatt67
Post by cookmatt67 »
Hello all, need some info and maybe a pic of the mounting location of the warning flasher switch on a 67 bump. The length and location of the harness on my truck sugjests that it is mounted in the glovebox, but i'm not certain of that or how it would be mounted. any help would be awsome. tks in advance..
Re: warning flasher switch location
it does mount in th eglove box. there are holes in the glove box that the flasher switch bracket will line up with. after the bolts go through the bracket and glove box there will be a reenforcement plate on top of the glvoe box. that the bolts go through.
cookmatt67
awsome!! ths for the info. slowly getting all this under dash wiring straightened out, now to finish up the curtosy lights and the washer wiring woo hoo
