F150 question?
hotrod ford
F150 question?
Post by hotrod ford »
My brake pedal/master cylinder on my 05 F150 has bee making a sound when it is pressed. It is like a dull squeaking noise. I have looked on line and in my hanes book but can't find any symptoms like this. I hope my master cylinder is not going bad. :pray:
Mancar1
Re: F150 question?
Post by Mancar1 »
Did you check everthing for tightness? Could it be your brakes themselfs making the noise. It is common from disc. brakes.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
hotrod ford
Re: F150 question?
Nope, not the brakes. When the truck is parked and off in the driveway I press the brakes and hear it. Just a bit ago I had my wife press them while the hood was up and it really sounds like it is coming from the master cylinder. Could it be the rod from the pedal going into the m/c? Could it need to be greased or lubed up of some sort?
Mancar1
Re: F150 question?
Post by Mancar1 »
If you have good brakes and no leaks your MC is probably ok. I would spray a little lube up in there on the rod and see if it stops. Also, sometimes your pedel mecanisim can be squeeking.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
TNIceWolf
Re: F150 question?
Post by TNIceWolf »
Do you have power brakes? If so the noise may actually be the booster operating on residual vacum.
Presently in the stable
1969 Ford F-350 DRW
hotrod ford
Re: F150 question?
Today I had a sign that somthing may be wrong with the brakes. Coming to a stop and kinda had to pump the brake pedal to get pressure. It was not a lot but it was enough to bring up a red flag. There is plenty of fluid and there are no leaks anywhere.
cdeal28078
Re: F150 question?
Post by cdeal28078 »
Any lights showing on the dash? I would think an 05 would have a warning light for a brake problem. Sure cannot say that as a fact though as I have never sat down in one. lol
If it is a real squeak I would do some lubricating like stated.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
