1969 F100 4 Wheeler
1969 F100 4 Wheeler
Well I got tired of making a bunch of new topic on the same truck so I decided that I will put all my questions on here, because we all know that I got alot of them. Here is the link to all the photos I have now and all the photos I will be putting on:
http://s1111.photobucket.com/albums/h471/usmcjones1988/
Re: 1969 F100 4 Wheeler
Well yesterday I got a new EZ wire harness in I got the 21 circuit 18 fuse harness. Also I got new window seals, door seals, new lock set, window handles, which I already broke a screw off in the knob nipple
I guess Ill just keep that handle on the dash. I already put the drivers side seal in that was an experience but i hope it just stays in I used half a tube of sealant so it should be good. I plan on finishing the passenger side, than start pulling all the old wiring out by the end of the day.
Well I stripped all the old wires out what a rat f***. I kept some of the pig tails, but im thinking of just using terminals instead of the pig tails I think that it will give it a much cleaner look not sure? I kept the wire that was already hooked up to for the wipers there was 4 wire coming out of it im guessing 2 for each speed? Also finished up the doors seals kinda mess looking but as long as it gets the job done im not looking for a show room finish. Here some pic of what it looks like after the wires were all pulled out:
Well that is the easy part now comes the FUN part I think im might just wait for tomorrow to start no reason to start running wire this late in the afternoon.
Anybody got an idea of a place to put the fuse box beside the original spot?
Does anyone know what this does or if its important:
How much bigger is the new one?usmcjones1988 wrote:Anybody got an idea of a place to put the fuse box beside the original spot?
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
about double i was thinking on top of the inner fender but i have a feeling when i go thru mud its going to get covered.
usmcjones1988 wrote:about double i was thinking on top of the inner fender but i have a feeling when i go thru mud its going to get covered.
-Mike-
ECV 1849
ECV 1849
usmcjones1988 wrote:Does anyone know what this does or if its important:
http://i1111.photobucket.com/albums/h47 ... 030092.jpg
Hazard Flasher Maybe??
55F100
55F100
I think i might just suck it up and put it in the stock location. I through the hazard relay was in the dash but who know i just hope i dont need it
- basketcase0302
That looks like your horn relay to me. Where underneath the hood did it come from?usmcjones1988 on Fri Sep 02, 2011 5:35 pm
Are you simply replacing the fuse box, or are you trying to rewire the entire truck?
- Ranchero50
Fixed your pics
That thingy is indeed your horn relay.
Jamie
Jamie
how did you fix my pic i would love to know ya i say it in one of the wiring diagrams that that what it was but i an rewiring the whole truck with an ez wiring harness.
- Ranchero50
Using photobucket, click to copy the text block that has img and /img in brackets. You can edit one of your threads above to see how it looks.
Jamie
Jamie
ok THIS IS A TEST ONLY A TEST ONLY A TEST
