Can I put a compressor in the basement?
flyboy2610
Post by flyboy2610 »
I live in a rented house. It has no garage and the owner is not likely to build one. I want to get a compressor big enough to run an impact wrench, impact hammer, grinder, air ratchet and paint gun.
I know I am looking at a large compressor with a 60-70 gallon tank. I would not even consider a direct drive, would HAVE to be a belt drive. My question is: is it feasible and safe to install this in the basement and run a hard line outside?
Or am I doomed to forever man-handling an inadequate compressor up and down the basement stairs( :x )?
crazy larry
re: Can I put a compressor in the basement?
Post by crazy larry »
i don't know why you couldn't. most shops have them outside, and pipe them in. just drain it regularly. doh'.
where does the tank drainage get to go?
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
I see no reason why you couldn't mount yours in the basement. It's probably not going to make your significant other very happy, as it'll rattle the walls while it's running....and getting it DOWN to the basement could be interesting, depending on how you're set up. As long as you have the necessary electrical hookups, I'd say go for it.
flyboy2610
Thanks, guys.
I will probably do it when I can afford it. Air tools would make my life SOOOO much easier!
dotcentral
Post by dotcentral »
Did you ask your landlord if its okay? He might have a problem with it.
Maxum96
Post by Maxum96 »
Don't set it directly on the basement floor if it's concrete. Put something (i.e. small pieces of plywood or squares of thick rubber cut from a mudflap) under the feet. I found that if you don't the compressor makes a lot more noise because it will vibrate on the concrete.
jor
Post by jor »
Yea, getting it down there could be really difficult. Then you've got to figure out how to run your piping outside. I'm thinking you don't want an open window in Nebraska!
jor
Big D's 69
Post by Big D's 69 »
I put mine in my carport. It is very quiet and very efficient. I left mine on the wooden pallet and have had no problems out of it.
rjewkes
Post by rjewkes »
Perehaps you could build a outdoor closet for the compressor just a little wider with vent holes built in for it to breath.
67F250CS
Post by 67F250CS »
rjewkes wrote:Perehaps you could build a outdoor closet for the compressor just a little wider with vent holes built in for it to breath.
Thats a good idea. I see those heavy plastic storage building a the Depot for less than 100 bucks. As long as theft is not much of an issue I would say go for it.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
rjewkes
Post by rjewkes »
of course parking something right against the door might just prevent Theft. That or a big old gaurd dog.
btgold29
Post by btgold29 »
I gut a good one....the guy, Bob Meduox who painted my truck had his compressor in the basment and he said it drove his ol' laddie up the walls, exspecially when he would forgett to unplug it before he went to bed lol
just something to think about
68-f100, 466 ci, tremec five speed, strange rear end, 35 spline axles, 542 hp 535 lbs torque @ the fly wheel. hand built custom headers.
Big D's 69
The one I have in my carport even if it comes on you can barely hear it in the house. The old lady wasn't real happy about me drilling a hole though the wall for the 220 power, but she got over it after the fact.
