Today was the first full day I've owned my '72 F-100. I started by giving the interior a thorough cleaning...pulled the seat, vacuumed a ton of old pine needles, stink bugs and spiders, and then scrubbed a bunch of mildew. The dash vinyl is permanently spotted from the mildew. I don't know if someone left it sit with the window open (or leaking) or what, but it wasn't leaking yesterday when I drove in the rain, so hopefully that is behind me.
I pulled the instrument cluster, in hopes of discovering whether my dash gauge lens was dirty, or permanently discolored and hazy...it's hazy and yellowed, but some polishing compound made it significantly better than it was.
Driving home yesterday, I spelled lots of exhaust/engine fumes; well, it was windy and some times I had a tail wind. But I also discovered I didn't have the steering column firewall boot, nor did I have the firewall boot for the clutch rod. As a temporary solution, I redneck-engineered a grommet out of an old bicycle inner tube, a ziptie, and some rubber cement. Hey, it works!!!!
The seat belt on the drivers side didn't work at all (they aren't original...heck, they aren't even Ford), so I took it out and got it operating properly. Then I re-installed the center seat belt set.
Back to the dash... I realized through some reading that the Ranger XLT in '72 had ammeter and oil pressure gauges. However, my truck has idiot lights (ALT gauge and oil light). I've also got a 2-spoke steering wheel with two horn buttons and no wood grain. The rest of the dash has wood grain. Unfortunately, the plate that describes the body style as built is missing (probably lost when the cab was re-painted). Any guesses what exactly I have here? A Ranger with XLT badges; a standard F-100 with Ranger XLT chrome trimwork?
Tomorrow's work:
After some research tonight, I discovered some possible reasons why my dash cluster lights might be inoperable, so that will be tomorrows first project. Then, I'll go into the engine compartment and do some digging there. For starters, I know something is screwy when I see, sitting in front of the air filter, the ignition coil just sitting on top between the valve covers!!!! Was that standard or someone's field expedited solution? I also know I don't have a gasket or seal for the oil fill cap on the left valve cover, and the vent hose on the right side is kinked so much that it can't be passing any air (it is a simple piece of non-formed hose).
Then, I'm going to go DRIVE IT!!! And take some pics, too!!!
