Grit size
Mancar1
Grit size
Post by Mancar1 »
Got a JobSmart 20 gal blasting pot yesterday. I was going to get Black Diamond from Tractor supply, but I think I will use no bigger than 80 grit to avoid as much clogging as I can. I may get the Garnet, but it is $$$. I figure I can reuse it. Any input anyone.
Gotta get Mom's cookin stove chimmney hood redone. Seemed like a good reason to buy a blaster, as someone on here mentioned :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
flyboy71
Re: Grit size
Post by flyboy71 »
Id go for True Grit
-Jeff
sargentrs
Re: Grit size
Post by sargentrs »
I've tried the 20-40 grit Black Diamond original and the 30-60 grit Black Diamond Fine Fury blend. The original was great at removing really gunked on crud and heavy rust scale but left a pretty rough surface. The Fine Fury took a little more effort and time but left a much smoother surface. I'm currently using the Fine Fury on my suspension components and after topcoating it leaves a good smooth finish whereas the original left a finish you could tell had been blasted. I wouldn't use either on exterior body panels without sanding them down smooth before painting. I didn't know they had an 80 grit. I'm just using a cheap blaster and have had no issues with clogging with either grit. It's a 20 year old Sears model pot with a cheap Northern Tool gun. I was going to buy one of these http://www.harborfreight.com/portable-a ... 37025.html and it'll probably work as good as the one I've got. Good luck!
Mancar1
Re: Grit size
Post by Mancar1 »
flyboy71 wrote:Id go for True Grit
[ Image ]
I tried.....but Rooster kept screaming and clogging the nozzle.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Re: Grit size
Post by sargentrs »
I'm gonna call BS on that one. Rooster Cogburn NEVER screamed in pain. LeBeouf maybe but not Rooster. :wink:
flyboy71
Re: Grit size
Post by flyboy71 »
You could subscribe to Grit too. :lol:
http://www.grit.com/
-Jeff
Mancar1
Re: Grit size
Post by Mancar1 »
sargentrs wrote:I'm gonna call BS on that one. Rooster Cogburn NEVER screamed in pain. LeBeouf maybe but not Rooster. :wink:
If it would have been the original, no way. Not the Duke, but alas it was a imposture. (Although it is a great movie. Both times.)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Re: Grit size
Post by sargentrs »
Ok, you win on that one. I saw the new one and it was ok but I waited the whole movie to see that last scene where Rooster puts the reins in his teeth and yells.. "Fill your hands you Son of a B----!" only to be disappointed. Bridges didn't pull it off like the Duke did. I thought he did bring a good gritty edge to Rooster while John Wayne's was a softer side. Still a good movie though. I thought the very end scene was good too. Nice close. Let me know how your blast job turns out and what you wound up using. Thanks!
