...It still needs a little more
http://www.youtube.com/watch?v=p8cyogt7 ... AAAAAAAAAA[/video]
Messed With The Timing Today...
Forum rules
Videos are only allowed in the Video Gallery forum....not in a post in any other forum. Videos posted to any other will be immediately moved as needed. One video per thread, please! Nothing allowed of an adult, political or religious nature. For further rules and how-to's, click here.
- BobbyFord
- robroy
Re: Messed With The Timing Today...
Good evening Bobby,
That's excellent--I loved the video! It sounds crazy!
What are your timing settings now?
Robroy
Robroy
- BobbyFord
I went from 12 initial to 14. I think it'll like 16 better, I have some higher-than-pump octane fuel in it now and I'm just experimenting with my seat of the pants dyno
I really would like to put a shorter gear in the rear and see if that wakes it up off the line. I may need more tire then, too. I could really use a little more converter, too
- My427stang
Hows the truck set up now Bobby?
Gear, engine, timing curve, tranny, converter, etc?
Also sounds like it'd be happy to shift just a little higher
- BobbyFord
Right now I'm running a 3.50 gear but I have a 4.11 gear set somewhere (I think). The short gear is what I'll run if I ever get to the track.My427stang wrote:Hows the truck set up now Bobby?
Timing curve
1000 4*
1500 12*
2000 20*
2600 24*
Vac advance is 10* at 18"
Trans is C6 with TransGo shift reprogrammer kit
I believe the converter is 2500 or 2800 (prolly 2500 if I remember, can't find the paperwork).
I know I'm shifting a little early, just haven't gotten to that yet either
![Sad :(](./images/smilies/icon_sad.gif)
I think in the video, it shifted early because I was feathering the gas. If I would have mashed it, I'd been on the other side of the road
- My427stang
What do you have for a cam, heads and intake?
- BobbyFord
C9 heads, milled, max ported, 2.19/1.76
Port matched Weiand Stealth intake
850 vac carb
Solid, flat-tappet cam .553/.575, 231/241 @.050 108LSA
Zero deck D1 block, 22cc TRW's
850 vac carb
Bobby, that sure does sound lovely.
Post another video when you can.
I sure did enjoy this one.
Congratulations, you have worked on it long & hard
but it sounds like it was well worth it.
